Originally posted by Studman
View Post
24 ve bubbles in boat
anhaney
Originally posted by Ruune View Postdoh! my bad... thats the exact kit I got, except mines red.
On another note, here's what spectrum color has to say about blistering:
This condition is caused by faulty workmanship. (I have a hard time believing this is the case. It was probably left in the water 24x7) Although there is no structural impairment involved, such areas should be repaired to prevent the exposure of fiberglass fibers from wicking water and gradual eroding.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Thats gel coat blistering, and why you dont leave a boat in the water for extended periods of time. Not going to be cheap, but you need to have it looked at by your dealer. The fiberglass can start wicking water from the blisters and then it contaminates your fiberglass lamination.
out of curiosity, is the lake salt water or fresh?Freude am Fahren.
I would contact TIGE' on this direct. I know that $1500 is not even close enough to get the right gel coat guy to fix it. Gel-Coat takes the right person to fix it.www.automarinecare.com CWB, ACME, FlyHigh, Merc Marine, PCM, Marine-power, WETSOUNDS, HSE Volume Controls, Kicker, Sony, Samson Sports, and many other marine parts or accessory's.
from http://www.tige.com/warranty.php :
The Tigé LifePlus Lifetime Replacement Warranty fully covers the integrated LifePlus Core construction of the boat, which includes hull, stringers and flooring. Buy a new Tigé, and if there is ever any structural failure, degradation or delamination for as long as you own your boat, Tigé will replace it with a new boat at no charge. Other boat manufacturers offer hull warranties that cover only the repair of defective lamination or structure. This usually means the owner is responsible for transporting the defective boat to the manufacturer for repair. The owner is then left with a repaired boat that seldom performs as well as the original."
make sure its checked for delamination in or around where the bubbles are. Although unlikely, its better safe than sorry. Tigé uses a tremendous amount of resin (I believe its 30% more than the competition), so their fiberglass shouldnt wick up water and delaminate easily... if at all. But, like I said.. better safe than sorry.Last edited by Ruune; 01-15-2008, 03:02 PM.Freude am Fahren.
Do you have pictures of the bubbles?The laughter of the world is merely loneliness pathetically trying to reassure itself. - Neal A. Maxwell
Originally posted by kmosley View PostHere's a picture of what the blistering looks like. The boat is now at the Tige factory in Texas and I'm waiting to here what they're going to do.The laughter of the world is merely loneliness pathetically trying to reassure itself. - Neal A. Maxwell
HOLY CRAP!!!
That's a 2007 boat? That is totally unacceptable. They can't really argue that the damage shown there doesn't fall into the "degradation" category per the verbage on the warranty. If that's not degradation I don't know what is!
Good luck.Other than that, Mrs. Lincoln, how was the play?
