Fueling up with the boat in the nose down position, to get rid of the 5 gal air pocket.
Things learned
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
Never yell at the wife or girlfriend wile they are trying to put the boat on the trailer.
Don't oil the teak swimstep the night before you go out.Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
Spray Sunblock (I.e. Coppertone Spray Block) will temporaily bond itself directly to the Gelcoat. Make sure everyone stands up (make sure there is no boat down wind from where you are spraying) and is in a location so that the overspray does not end up on the gelcoat. I typically stand on the platform or in the bow, standing up on the seats.
Originally posted by CP3 View Postthe nose of the boat being down I would think
In our '95 Tige we NEVER had a problem fueling up, whether it be kicking off 10 gallons early or getting the fuel shower, we never had a problem. In that boat the fuel fill was on the transom in the middle parallel to the ground. Whenever we filled it we filled with the pump straight up. I'm wondering if you turned the pump 180 degrees from "normal" when using the side fills if it would help vent/flow/etc and would possibly prevent the geyser.. any thoughts??If you ain't falling.. you ain't trying hard enough..
anhaney
Passengers
Always tell the passengers to not let the rope out over the seats at high speeds. It burns a rope burn into the vinyl.
unloading
Ensure the moron holding on to the dock line knows that when she hears the nasty grating sound of gel coat peeling off on to the trailer guide post that she should stop pulling on the bow line lest she increase the size of the already beautiful new scratch she just put in. Then make sure she knows you're really pissed and that her best response should be "Dude, it's not a big deal, it'll probably buff out. My friends Bayliner has a lot of scratches, it's no big deal."
Then never invite said friend out again.Other than that, Mrs. Lincoln, how was the play?
Originally posted by Jason B View PostEnsure the moron holding on to the dock line knows that when she hears the nasty grating sound of gel coat peeling off on to the trailer guide post that she should stop pulling on the bow line lest she increase the size of the already beautiful new scratch she just put in. Then make sure she knows you're really pissed and that her best response should be "Dude, it's not a big deal, it'll probably buff out. My friends Bayliner has a lot of scratches, it's no big deal."
Then never invite said friend out again.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
