Just wanted to see if anyone else has encountered a similar problem..
Went to the lake yesterday after work and before going we filled up. We have an '07 22Ve w/ the dual fuel fills. We always fill from the port side (the one w/ the fuel vent right under it) but open both sides to help vent. Anyways we filled up yesterday and headed to the lake. When I got in the boat I noticed a fairly strong fuel smell but thought it was just b/c we had just filled up. Ran across the lake at WOT to try and burn a lil gas to get the smell to go away.
We got to the other side of the lake and I surfed for about 20 min and then got back in the boat. Still noticed a VERY strong smell of fumes. Opened the engine compartment and I could see some sort of fluid at the bottom of the hull, below the engine. I thought it was just water but the fumes were so strong that I thought I better check. I grabbed out flag and stuck the wooden handle down into the bottom of the compartment and sure enough.. the liquid was raw fuel!
Immediately drove back to the dock and headed home. I was just wondering if anyone else has had a fuel leak problem in their boats..
I'm 99% sure that there is a leak somewhere in the starboard side fill line b/c as the boat sat overnight, no more fuel ended up in the bottom and the gas gauge didnt drop at all. I think we were just pumping gas in to the bottom of the boat via a leak in the hose. Took it to the dealer this morning and they are checking it out but was just wondering if anyone had any thoughts/opinions/past experiences..
