Well this is weird, we took some water over the bow yesterday and it was storming when we pulled out of the lake so the front carpet got pretty wet. I went out this morning and pulled the carpet out and it smells exactly like cat pee, just like you said! It's dry now and doesn't stink.
2007 22 Ve Carpet odor???
Same with me, if the front carpet gets wet at all...... and wham....... we get the cat pee smell.
Tige' needs ( or better) to look into this asap, as it clearly is in the production of the carpet they use.
It's hard to justify to guests on board that a new boat smells like cat piss.
Tige' you reading this?Tige owner since 2006
Wet bow carpet - poor drainage
We have experienced the same odor problem... when we take water over the bow -the front storage compartments under the bow seats trap some of the water and are very slow to drain - we usually have to hand pump the water out - The carpet in those bow compartments is where most of our odor is coming from.
Anyone else experiencing slow or non-draining bow seat compartments? There are no visible drain holes that I can find.
I spray on squirrel urine to counteract the cat urine, it's called "CatPissBgone".
www.catpissbgone.com
Seriously, I don't have any problems yet with stinky carpet and I am lazy and will leave my wet fat sacs in the lockers for a few days before I take them out to dry. However, I do live in a very low humidity climate and my boat has had 7 years to get rid of the smell.Last edited by Moki; 07-19-2007, 07:57 PM.
Originally posted by rockbandit View PostWe have experienced the same odor problem... when we take water over the bow -the front storage compartments under the bow seats trap some of the water and are very slow to drain - we usually have to hand pump the water out - The carpet in those bow compartments is where most of our odor is coming from.
Anyone else experiencing slow or non-draining bow seat compartments? There are no visible drain holes that I can find.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Anyone else experiencing slow or non-draining bow seat compartments? There are no visible drain holes that I can find.Okay, this is your first post. We all want to see pictures of your boat now....
We like to see other Tige's and what each member has.
Originally posted by da.bell View PostWe like to see other Tige's and what each member has.
That's ok, a pic of your Tige will do just fineMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by da.bell View PostYup, have the same problem in those areas. I think chpthrill is doing something with this because his original fix didn't solve the problem..... I could be wrong here.....
It's a work in progress, no more puddling in the bow but wet in the port console nowHopefully I will get around to Rhino Lining next week.
