Courtesy lights don't work
    The courtesy lights on our 2006 22V do not work. We think the fuse may be blown and needs to be replaced. Is it the fuse on the dash that needs to be replaced? If so, how do you remove and replace it? Also, how do you know what type of fuse to use and where can you get one?
    I know this is simple stuff, but any help would be really appreciated.
    I had the same thing happen on mine.
    I was just a loose connection. I just got under the dash and started pushing together wire connectors and it ended up working.
      I had the same thing that CP3 described happen to me. Except it was my Taps. The nut had came loose on the back of the Taps guage. Check the connections on the back of your switch.
      Actually my courtesy lights in my bow have stopped. The others all work, just not those two. I haven't got around to tracking the problem down just yet.
      Being a major OU fan and a staunch conservative.... I am perpetually vexed w/ the conundrum of who to hate more. Obama or the Univ. of Saxet.
        Mine stopped working because the breaker kept tripping. The cause...the lights above the battery compartment burned out. The breaker should just reset on your dash but if it keeps tripping you will need to find the cause.
        "the plural of boo is booze."
