Thanks Dogbert!
Perfect Pass Question
Originally posted by talltigeguy View PostZad is right. The PP can be set for how often it checks the speed. If you have it set to check the speed too rarely (every 3 seconds), then it makes adjustments that get wild. It can be set to check the speed more often, and that will decrease the swings in speed. The owner's manual should tell you how to do that. Mine was initially set to check the speed too rarely, and I fixed it and have never had one complaint. I don't even have to mess with the throttle on a double up.
I have never had a problem with the speed based mode. I can't help but think that once a person pulls hard on my boat and slows it down, if the RPM's are held stable, it will take 5-10 seconds or more to get it back to the speed we like. It would take even longer with heavy ballast. I have never tried it in RPM mode, but it just does not make sense to me.
The only thing we use speed based mode for is surfing........ I dial up 9.5 mph and we go. The surfing doesn't cause any issues on my boat as for the boat surging. The only time the RPM's lose much speed is doing a tight turn.....we never really do that so it isn't an issue in our case. The speed based setting just seems to be revving up and down and therefore taking away and giving tension on the handle. I know that everyone has their favorite way of doing something.......but we just prefer the constant pull on the handle from the RPM mode. Just my
Originally posted by wakeboarder247 View PostIs that what you're supposed to do? WOT? When we engage our Tige SpeedSet we get to speed push set and then give it a little gas.. (what the dealer said) We haven't had any problems with surging but just wondering if taking it to WOT vs. just pushing the throttle down some makes a difference...
Originally posted by chpthril View PostMy dealer had no clue how to use, not that it worked on delivery anyway, and no manual was provided. I found some posts on here and that's what seemed to work. I do know that it will surge if you leave the throttle where it is when it engages. You may not have to floor it, but it works for me.
Originally posted by da.bell View PostNot sure about SpeedSet but I don't see why it would be any different then AccuSet on the throttle. However, I wouldn't suggest WOT but maybe a slight push of the throttle would be best.
Accu-Set is done electronically through the Marine Power ECM via Throttle-By- Wire. No mechanical link to throttle like PPMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Another Thing is if that its a Big guy you probably slammed the throttle down and the time the PP kicked in the engine would have been up to 30, and it pulled the throttle to drop the speed and once it hit the speed it had to speed up again.. and so on.Common Sense is not so Common
Your supposed to put the control to almost wide open on either system, for pp if you dont give it wide open it will eventualy burn up the servo which we replace quite a few of ,and on the tige cruise the computor needs to see a wide open command to have room to bring up the throtle in the turns.
Originally posted by FIC View PostYour supposed to put the control to almost wide open on either system, for pp if you dont give it wide open it will eventualy burn up the servo which we replace quite a few of ,and on the tige cruise the computor needs to see a wide open command to have room to bring up the throtle in the turns.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Tigé Jedi
- Feb 2004
- 5557
- St. George, Utah
Originally posted by FIC View PostYour supposed to put the control to almost wide open on either system, for pp if you dont give it wide open it will eventualy burn up the servo which we replace quite a few of ,and on the tige cruise the computor needs to see a wide open command to have room to bring up the throtle in the turns.Be excellent to one another.
Originally posted by talltigeguy View PostExplain how to do that with PP. If I throttle up to speed, and keep opening up the throttle, I can 'override' the PP and get going too fast. My wife has had me wakeboarding at 32MPH many times, it isn't much fun. Maybe if I do it a milimeter at a time...Common Sense is not so Common
Originally posted by FIC View PostYou can still throtle up your normal way once pp beeps and settles in you can throw the throttle down and it will stay at its desired speed.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Tigé Jedi
- Feb 2004
- 5557
- St. George, Utah
Originally posted by FIC View PostYou can still throtle up your normal way once pp beeps and settles in you can throw the throttle down and it will stay at its desired speed.Be excellent to one another.
