So I think I finally decided on where I'm going to mount my Satellite antenna. I'm going to unbolt the front tower leg on the port side of the boat and snake the wire underneath. I need a good adhesive double sided tape or velcro that is going to withstand the LV heat, any suggestions?
Double sided tape
What I did was run the wire up the tower like a speaker wire and have it come out by one of the board racks. I got some 3M heavy duty velcro with tape on the back side and put one side on the back of the antenna and the other on the tower. I used the small micro antenna. I have had it up there for 3 years now and it has never come off.
That's a pretty heavy piece Dom, i'm not sure tape would hold it with all the jarring around and stuff. What might work is if you use industrial velcro and completely cover the back of it. That stuff is unbelievable (the industrial) and doesn't let go easily. If you were to do that and also have a heavy duty velcro strap going over the top that should hold it good and allow you to remove it as well."Call me anything you want ... Just don't call me NOBODY!
I found some at Home Depot that comes in strips, i used that for attaching various stuff under the bow and gunnels and it hasn't moved yet! Lowes & Orchard Supply might have it too! Make sure to rub down anything you attach it to with rubbing alcohol of at least 70%. It almost reactivates the resin and makes a great bonding suface."Call me anything you want ... Just don't call me NOBODY!
ok, gotta get velcro and rubbing alcohol, good deal. I'l check home depot, since it's 2 blocks from my house. I'll mess with later, wanna get everything wired first, then worry about keeping the batteries charged.Originally posted by G-MONEYIt hurts me to say it but go OU but only for this weekend!!!!
ok, good deal. Thanks all, i'll give it a wirl! I hope it works, as that place would be the trickest place for it, close to all banks, and out of the way, dry and a place for the plug is very easy to obtain.Originally posted by G-MONEYIt hurts me to say it but go OU but only for this weekend!!!!
