The Ultimate Run Dry Impeller
    Hay Capitalgain, have you gotten any info about our Tige Owners Day next Saturday the 9th? I sent a couple of Private Messages. Hope to see you there
    Event info thread: http://www.tigeowners.com/forum/showthread.php?t=3172
      Originally posted by capitalgain View Post
      I just bought a brand new pump complete with pulley for $275 (includes $25 shipping). There were four more available. These things retail for $428.
      http://cgi.ebay.com/ebaymotors/MERCU...spagenameZWD1V
      Are you having problems with your pulley or did you just get it to have an extra?
        My pump locked up when I was running the boat in the yard. I thought the bearing had gone out and to replace it I needed an arbor press and special puller so I just decided to buy a new pump. After I pulled the pump, I think I was wrong...all I needed was the impeller (although I haven't looked at the housing yet..it may be bad).
        In the end it has worked out since I plan to rebuild the spare pump each winter.
          Thats a great deal if it fits your engine.
            capitalgain, What is the quicksilver part number? I noticed that the box has quick silver on it.
              Common pump
              It is not hard to match up diffrent pumps to your engine and run them. The big thing you have to be carefull of is not to get a pump that is two big. It will rob horsepower and that helps to suck gas. The pumps on TIGE'S unless it is a PCM engine are very common place on other marinizers. They are pretty easy to come by.
                Tag on box reads Quicksilver 46-807151A9. You can find the part # for your engine online although it's not that easy to do (at least not for me). Mercruiser made a kjillion variations of the small block chebby...
                If you need the website, I'll see if I can dig it up.
                  My source has 30 in stock List price is 449.91. I can get them at my cost of $275.00 but that does not include freight. I am sure that freight is not truly $25.00. It can't be more than 10 Lbs for that pump and that is a high flat price on freight.
