G is that you with the beer bong?
Memorial Day Pics
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
It's only about 300 mi from Bako.Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
Battery Charging Question
I just installed an isolator and have a question in regards to charging. I haven't needed to charge the batteries since I have added high output alternator, but I have question if and when I need to. I have three batteries and two are ran in parallel. What is the best way to charge the battery, should I unhook the wires from the isolator and charge or just leave connected? If I hook up to one of the batteries that is ran in parallel, will it still charge the other battery if the isolator is connected or does the isolator just control the flow from the alternator?
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
Originally posted by Moki View PostI just installed an isolator and have a question in regards to charging. I haven't needed to charge the batteries since I have added high output alternator, but I have question if and when I need to. I have three batteries and two are ran in parallel. What is the best way to charge the battery, should I unhook the wires from the isolator and charge or just leave connected? If I hook up to one of the batteries that is ran in parallel, will it still charge the other battery if the isolator is connected or does the isolator just control the flow from the alternator??????????????
anhaney
Originally posted by wakeboarder247 View PostThis is how my local lake is every Sunday from the week before Memorial Day weekend to the end of September.. crazy parties in the back of the lake where you can easily get 30-40 boats tied up in the middle... nuts!! This is why I love summer...
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
Moki
Did you want to post that in this thread?Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
anhaney
Moki, one side of the isolator should be hooked up to one battery and the other two WELL while are they in Parallel? Those two could be hooked up to the other side of the isolator if they are in sieries. I am not sure what would happen if you tried to hook up two batteries in parallel and then tried to charge them the effects might get ugly.
Originally posted by Moki View PostI just installed an isolator and have a question in regards to charging. I haven't needed to charge the batteries since I have added high output alternator, but I have question if and when I need to. I have three batteries and two are ran in parallel. What is the best way to charge the battery, should I unhook the wires from the isolator and charge or just leave connected? If I hook up to one of the batteries that is ran in parallel, will it still charge the other battery if the isolator is connected or does the isolator just control the flow from the alternator?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by G-MONEY View PostMoki
Did you want to post that in this thread?Sorry about that G-Money, I did not mean to post in this thread. I think it was the black tape pastie that got me confused.
We now return to the much more exciting thread than isolators!
