Does everyone find that the system makes there motor jerk when you get to speed? When I get at speed it almost acts like I hit a rev limiter. I am also having all kinds of problems with my motor.I have the 6.0 and it has no power and at times has carbon coming out of the exhaust after a fast run. It wont rev over 4200 RPM with 8 people in the boat and no ballast.
Tige cruise
No but If wires dont have to do with it, since your saying carbon comes out of the exaust u either have Fouled plugs almost like (cylindars not firing) or Your injectors are putting in too much gas! Which is burning more than it should then it wont fire all of it and just wastes oil and gas then that will come out of your exaust and do what your saying. But Just fool with the wires first before going to a boat Dealer/mechanic to hook the computer up to see about tuningFor Those About To Ride We Solute You
Originally posted by ddmracing05 View PostNo but If wires dont have to do with it, since your saying carbon comes out of the exaust u either have Fouled plugs almost like (cylindars not firing) or Your injectors are putting in too much gas! Which is burning more than it should then it wont fire all of it and just wastes oil and gas then that will come out of your exaust and do what your saying. But Just fool with the wires first before going to a boat Dealer/mechanic to hook the computer up to see about tuning
Originally posted by THE g View PostI checked all the plug wires ect,did not have a chance to pull plugs as it started to rain as it has been for two weeks. The next problem is the Tige dealer is no longer the Tige dealer, I talked to them yesterday but it sounds like it may be a few weeks before they can look at it!I am sure it is a ECU type problem.
I have the same cruise "Tige" and was told that because it dials in the speed quicker and holds a more acurate speed compared to the surge of my old perfect pass that the motor cutting like it does is supposed to happen. I have had mine out a couple of times now and it seems to be getting better or I am just getting use to it.
Originally posted by THE g View PostI talked to marine power and they think it is a bad senser but you need MEFI 5 to read the codes and reset them. The dealer here does not have it so I orderd my own so I can do the work myself.
Mine will surge if I dont put the trottle to WOT after the cruise takes over. The 07 RZ2 we drove last Nov at the Lke Mead Reunion did it also. Same engine, mine with "Accu-Set" the RZ2 had "Tige Speed Set"Last edited by chpthril; 05-29-2007, 06:13 PM.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostHow much for that little baby and will they allow you access to software updates? I would consider one for myself
Originally posted by THE g View PostThe software and cables where $699, they will let me see and reset codes and read data in real time and data log. I think with some software from Marine Power and maybe passwords even more.I got it from www.rinda.com
There were some threads on here about the 6.0's vapor locking, may find if you do a search.Last edited by chpthril; 05-30-2007, 01:43 AM.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
