ok so just got my 20V 06 from previous owner...previous owner says Dual battery system has an isolator and stereo equipment is seperate from engine battery so if you kill stereo battery listening to music boat will still start on the other battery. My question is both battery switches engine compartment and under seat need to on to turn on the stereo. wouldnt that mean that they are not seperate? Can someone explain.
Newb. question
Originally posted by sacnvr2l8 View Postok so just got my 20V 06 from previous owner...previous owner says Dual battery system has an isolator and stereo equipment is seperate from engine battery so if you kill stereo battery listening to music boat will still start on the other battery. My question is both battery switches engine compartment and under seat need to on to turn on the stereo. wouldnt that mean that they are not seperate? Can someone explain.
Congrats and welcome to Tigeowners.comMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
thanks for the info...working on pics when the weather gets a bit better been cloudy and rainy here in seattle.
As for the 2 switches both look factory installed. one switch is under the sun deck next to the motor. Switch 2 is under the seats directly behind the drivers seat.
I guess when the weather clears a bit and it is warmer I'll just go out and see where the wires go and try to figure it out.
If this set up sounds familiar to anyone let me know how it works.
