What Kind Of Drill Bit To Use?
    What kind of drill bit do I need to drill through the gunwale? I will be starting the stereo install next week, at which point I will need to drill through the deck (under the tower mount) to run speaker wire up through the tower. Also, and size recommendation is appreciated.
    Hi-speed steel resist biting/chipping the most. Go slow w/lite pressure. It will go though the figerglass real easy but will want to grab when it hits the reinforcement plate.
    Start with 1/8th and slowly work your way up.
    I think that 7/16 will be just right for 2 wires.
      Drill in reverse.
      http://www.wakeboatworld.com
      []) [] []V[] [])
        So just a regular straight bit? I'm looking for bit type. Chp-start with a smaller bit first and then get bigger?
          No need to start small. Regular general purpose straight bit. Drill in reverse, use masking tape, and chamfer the gel by either turning a bit by hand over it, or using a chamer bit in reverse on a low setting. This is what I did, and my holes were perfect with no chips on very old gelcoat.
          []) [] []V[] [])
            I used a forstner bit the exact size i needed, they're extremely sharp. Like the others said, drill in reverse 'till you're through the gelcoat.
              I concur. Drill in reverse thru the gel coat. Then you can drill forward. No chipping what so ever.
              Let it be!!!
                Thanks. I do not mean to be a ingorant pest, but I do not know what "chamer" or "forstner" bit is.
                  Here's a forstner bit, it's a combination of a hole saw and precision drill bit. The nice thing is that they come in virtually every size. I got mine at Home Depot for $8 if i remember right.
                    Bigger pic showing the design...
                      A chamfer is a beveled edge in the gel coat that will help prevent spider cracks.
                      A forstner bit is a wood cutting bit. Would probably work good if just drilling through gel and fiberglass, but will not drill through the metal plate that is glassed in
                      The reason I suggested to start small and slowly work your way up was the metal plate itself. It will be much easier (IMHO as I don't have a degree in holeddrillology) to enlarge a pilot hole in the plate than trying to drill a single 7/16 hole. You would probably ruin the bit by time you got through the metal reinforcing plate.
                      Good luck
                        Chamfer bit looks like this; this one is for a router, but they are available for hand drills as well.
                        []) [] []V[] [])
                          Good luck
                          What metal plate you talking about? The only metal plate i have is in my head.
                            I took a peek at the hole that was driilled in BD's 06ve and I did not see a metal plate either. Doesn't mean it wasn't there...just that I didn't see it.
                              Once you are through the gel coat you need to take some 1500 wet or dry sand paper and sand around the edges of the hole. If not in a year or so you MAY regret that you didn't. This was not done on my boat but thankfully for me when I got spider cracks a year later the dealer accepted responsibility for it and took care of the issues since they did the install work. $3600.00 later spider cracks were gone. Just my two cents worth.
