Was on the Parker strip a few weeks ago and had the opportunity to tow a disabled boat. When hooking the line up to tow I recalled the treads I'd read about where to hook when towing tubes, and towing this boat would have alot more drag than that. So I hooked to the ski pylon and told the other driver I could tow him downstream and only at an idle. Do you think the transom is solid enough to support some sort of tow hook?
Towing with RZ2?
I think the transom will be strong enough. It just sucks not having a place to anchor the boat that is easy to get to or to tow a boat that you don't have to worry about. Tubing has not been an issue with us, but I don't go that fast with the little ones. I just don't know why Tige doesn't put a tow hook on the transom handle like they do with some of their other boats.Success is the ability to go from one failure to another with no loss of enthusiasm.
Winston Churchill
