Modification time
    I got them from TMI LED TECHNOLOGY
    http://search.stores.ebay.com/TMI-LE...016538QQsofpZ0.
    I have not finished yet, I plan on running the wires through some small tubing. I will shrink wrap each connection, also use some silicon inside the tubing to keep the wires dry.
    I then will epoxy the tubing to the edge of the swim deck. ( I kept the light ½ inch from the lip, in order to leave room for the tubing.)
    I am going to tie them in with my curtsey lights. I t will not be until June that I get a chance to see how they work. ( the lakes I go to locally do not allow you on after dusk)
    David W.
    Tige, it's a way of life!
      How about "before dawn" pictures? There's always a way around the system...
      Thanks for the info.
        Before dawn sounds good, do you have any pics of it on the ship???
        The sun never sets on a badass
          Must resist......... must resist.......... must resist.......... That looks cool I have the transom light but I think your lights looks better.
          4-7-09 And still employeed for yet another week (subject to change at any moment)have we hit bottom yet?
            Ok I almost done with the LEDS on the swim deck. I will do a water test in my pool tomorrow.
            If you ever need to run some wires inside of tubing, make sure that your splices are in different location. (If you splice in at the same length on both the + and – wire you will have a hard time pulling them through)
              I wish I had a pool just big enough to put some sliders in and use our winch. You get to go boating. Bowdon
                BLING BLING
                  Ok I did the test in the pool. It was at dusk some the sky was not black yet, but it lit up the deep end pretty good.
                  Here some pics.
                    Here are pics of a mod I made to my tower last year.
                    I installed some small florescent in between the tubing. This is why I placed my speakers on top.
                      Boat looks awesome. Great attention to detail on the switches.
                      Where did you get the docking lights?
                      Do they come with a template for the cutouts?
                        I got the docking lights from boaters world and they do come with cutouts have not been on the lake this year but look good in driveway
                          Originally posted by lee View Post
                          Better countersink those screw holes if you do not want spider cracks.
                          Not only do you want to counter sink the holes use some 1000 grit paper and smooth of the Edges of the cut hole and the edges of the counter sunk hole. Trust me my dealer learned $3600 later from gel coat repairs to do this on any hole cut or drilled in a boat.
                            Originally posted by Moki View Post
                            It looks sweet! I really like your stickers over the lenses. What are you using for a ballast system, did you make your own, Tige, or somebody else? I have been trying to decide where to put my switches. I really do not have room on my dash -- now I know.
                            Hey MOKI, I am coming back to Utah on may 14th 15th and 16th. If you are doing ballast I need to talk to you. I have some ideas for great system and we might be able to work a great deal on parts for it.
                              Takeing the time to finish the edges is more important than drilling the hole itself
                                I love that light bar. I bet that wasn't cheap.
