Not complete yet, but this is the mock up. I was playing around with light patterns.
Just wanted to show off my LED install
That is sweet
Please give us more info on the LED's and the install. Have you posted other pics of your boat.
Sent you a PM.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
The LED came from http://www.plasmaled.com/ledpods.htm. They are the 4 lights per pod and are super bright. I ran a small gauge wire from my switched running lights, but my change it to a seperate circuit so I can choose to run one or the the other at different times. I have 8 pods with a total of 32 LEDs. I have added one pod to each rear compartment, two in the front walkway, one under the drivers feet, the two at the back are actually above the cupholders and shine across on each other, and the last one is right below where the cushion for the front storage/cooler go.
They are mounted with doubled-sided tape that seems to be pretty strong, I will have to see how it holds up in the heat. Pretty simple to install, very low voltage drop, probably more in the wire than in the actual LED.
Let me know if you have any more questions.
Tigé Jedi- Feb 2004
- 4952
- St. George, Utah
The wood dash is cool too.
LED's are on a long list of things I will get to once I win the lottery and no longer need to work. For now, I don't get on the water enough.Be excellent to one another.
Toocool,
sweet set up. Take a look at Superbrightleds.com. I did the same thing with my 2001 21V but only in red. I changed out my gage bulbs for LEDs, and changed out all the interior running lights with the LED bulbs also. They have the 4, and 6 LED pod clusters. I have 2 front cabin, one under the dash lighting the sub, 1 under the glove box lighting the other sub, 2 forward, 2 cup holders in rear and 2 lighting the disco ball on my tower. Will post pics after we make it out this weekend.
Cheers TK
Disco ball on tower not a factory option, but should be. Met Will Farrell in Talladega Nights, I was an extra for The Old Spice Pit Crew. Wouldn't want to see him dancing on the back of my boat, ( he's a big dude). The ball and flashing light does seem to attract a few wild drunks chics though, guess I'll keep it.
I gotta see this disco ball you keep talking about man when you going out? PM me, Ill be hitting the water this weekend if it's nice.Originally posted by tktige' View PostDisco ball on tower not a factory option, but should be. Met Will Farrell in Talladega Nights, I was an extra for The Old Spice Pit Crew. Wouldn't want to see him dancing on the back of my boat, ( he's a big dude). The ball and flashing light does seem to attract a few wild drunks chics though, guess I'll keep it.
MichaelMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Tigé Jedi- Feb 2004
- 4952
- St. George, Utah
I have thought of a disco ball. I think it would be cool seeing disco ball lights flashing off of the sandstone cliffs at Lake Powell while echoing 'That's the way, Uh-Huh, Uh-Huh, I like it Uh-Huh, Uh-Huh' off of the canyon walls.
Please let me know how you have it set up. Pm me if you can or just post pics here.Be excellent to one another.
I'll get some pics up from this Friday night, we'll be out on a Booze cruise.
I just hooked it to the tower tow hitch, used some Dbl sided tape to attach the 2- 6 pod LED clusters. I had only one white LED shining straight down last year. Put the 2 red Led Clusters up and man what a difference
