Since I'm re-working the box for my amp rack, I figured I'd better think long and hard here about my fan situation. I'm down to 4 fans now... but my question/dilemma is this.... Two of my amps have been getting REALLY REALLY hot. I've added a second run of 0 guage wire which should help some... but not totally. Since this amp rack will be sealed it definately has to have fans. I was originally going to put 3 fans blowing on the amps and one sucking. I wanted to have the 3 blowing lengthwise down the heat sinks on the two Hot amps. I figured I'd get a vacuum effect which would force the additional air out. But I'm debating now if rather or not that's the best option. Do you all think I'd get more airflow by doing it with equal air in as moving out... (I.E. 2 fans sucking, 2 blowing).
The only reason I was considering not going with 2 in and 2 out is the fact that I was really liking the idea of having the fans blowing directly down the length of the heat sinks. I guess I could use the fans to cross blow the amps.
