Originally posted by zad0030
View Post
Boat Buckles
Originally posted by zad0030 View PostIs it absolutely necessary to have tie down straps in the rear?My dad always said "Stupid Hurts". He's yet to be proven wrong, but for some reason I keep trying.
You can get the buckles by that teak. I don't have the buckles but I strap it on everytime and I have about the same clearance. You obviously can't get the hook through but you can slide the strap past and then attach the hook."a what? i can['t] say/spell/pronounce that word..." - wannabewakeboarder
"the plural of boo is booze."
Originally posted by evil0ne View PostYou can get the buckles by that teak. I don't have the buckles but I strap it on everytime and I have about the same clearance. You obviously can't get the hook through but you can slide the strap past and then attach the hook.
I have not had any rubbing yet, but will stop it before it startsMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
anhaney
Just and Idea
I have an idea. If it quits raining long enough tomorrow I will go out and set it up to see if it looks like it will work. If it does I will post pics of it on my boat.
Tigé Jedi
- Feb 2004
- 5557
- St. George, Utah
I think it is definitely necessary to use the rear tie downs. Check out the pic I posted on page 3 of this thread. Rear tie downs would have made a difference. It is really the medium severity accident when the rear tie downs will save your boat. We went through this all before.
http://www.tigeowners.com/forum/show...traps+accidentBe excellent to one another.
Originally posted by mtnsmith View PostI think in Missouri you need them if traveling on the interstate or over 50mph, if I remember right.
Loads which might become dislodged to be secured--failure, penalty.
"307.010. 1. All motor vehicles, and every trailer and semitrailer operating upon the public highways of this state and carrying goods or material or farm products which may reasonably be expected to become dislodged and fall from the vehicle, trailer or semitrailer as a result of wind pressure or air pressure and/or by the movement of the vehicle, trailer or semitrailer shall have a protective cover or be sufficiently secured so that no portion of such goods or material can become dislodged and fall from the vehicle, trailer or semitrailer while being transported or carried.
2. Operation of a motor vehicle, trailer or semitrailer in violation of this section shall be a class C misdemeanor, and any person convicted thereof shall be punished as provided by law. ""I want to know God's thoughts, the rest are just details"
I attach the strap to the rear tie downs located on the transom. The strap slips easily between the teak platform and the transom.
I also use a rubber pad to protect the paint.
It is the yellow piece in the picture. I purchased it at West Marine. I only wished that it was red or black to match better.
Takes only a few seconds to attach and helps to really secure the boat down.
As an experiment try going over some bumps without the boat tied down and you will see it shifts around quite a bit.Attached Files
Originally posted by canuck View PostI attach the strap to the rear tie downs located on the transom. The strap slips easily between the teak platform and the transom.
As an experiment try going over some bumps without the boat tied down and you will see it shifts around quite a bit."Call me anything you want ... Just don't call me NOBODY!
Originally posted by anhaney View PostI have an idea. If it quits raining long enough tomorrow I will go out and set it up to see if it looks like it will work. If it does I will post pics of it on my boat."Call me anything you want ... Just don't call me NOBODY!
