i always make them on the smallest size and stuff, never had a problem.
A shot in the dark
Polyfill causes negative effects on sound waves, and your driver actually underperforms when it is in a polyfilled enclosure....although it may sound better. It is an absorbtion material, usually used to dampen the standing waves in an enclosure. It "warms" the sound. A couple of inches of polyfill lining will help "fix" a poor box design.
Say you built a box and it is a perfect square, when the bass hits it sounds flat. Adding polyfill will cause the sound waves inside the box to become irregular, in effect regulating standing sound waves. A standing sound wave is one that cancels out due to an opposing wave. This is real common in hatchbacks, and trunks. It is also sometime used to control the Q value os the rolloff of the driver. A sealed enclosure works by using the backpressure of the box to regulate the drivers excursion. Adding polyfill helps dampen the excursion of the driver in cases where it flexes too much. It sort of pushes the response curve of the woofer per tone up or down because of the change in backpressure.
Found a picture....see how the return wave reflects back a mirror of the sending wave, this cancels each other out, the result of a perfect standing wave is silence.
[]) [] []V[] [])
Originally posted by jleger98 View PostSo if i have a sealed box of about 1.5 cu feet or so and a 10" SW, polyfil? or no?
Polyfill will in most cases tighten up the response somewhat. I get the biggest kick out of drummers who stuff their kick drum with pillows and poly......they could tighten the heads, and get the tighter response without the reduced Q values or rolloff.
Originally posted by Domsz06 View Postsp
I had no idea, wow. Thanks for the info, I won't be adding any polyfill to my new boxes, wow and all these years......Last edited by spharis; 02-20-2007, 04:21 PM.http://www.wakeboatworld.com
[]) [] []V[] [])
yeah I'll have to look into that. Thanks though, that makes sense, I just never thought about it that way
does a box have to be square? I mean is it ok to make curved boxes?
Also when making a sealed box for 2 10's, do I need to separate them with a wall as well?
What about a ported box?Originally posted by G-MONEYIt hurts me to say it but go OU but only for this weekend!!!!
Originally posted by Domsz06 View Postyeah I'll have to look into that. Thanks though, that makes sense, I just never thought about it that way
Boxes can be any shape, but certain shapes are going to have adverse effects on the waves inside the box. I usually try to use right angles, or slight diagonals. Bose spends millions on developing enclosures to account for the sound waves inside the box.....there is too much science involved for me. It's easier to build what you want, then tune it up a little. It's going to be so loud it really won't matter that much in the end. The main thing is to get the driver to sound right.....IE not restircted or flat. Minor changes can fix this, like a small amount of polyfill, or adding bracing in the corners of the box.
The biggest killer of a good sounding sub is dead spots in the innner space (flat waves) and poor box materials/not enough rigidity. If the box flexes, the driver is not performing as it could, and obviously if the notes are cancelling internally, the backpressure is resricting the excursion......flattening the wave you hear.
Sealed boxes with a split is again used to help control standing waves. If you have a frequency with a 1 ft wavelength, and the drivers are 2 feet apart, then you will get a standing wave between them. A separation removes that chance. That said, I have heard amazing sound out of multiple drivers in a single space.
People who build awesome boxes have just built enough of them to know what works, or they got lucky. KNowing what works is usually the best method, but that involves alot of trial and error. I still don't know what works, but I try.Last edited by spharis; 02-20-2007, 04:35 PM.http://www.wakeboatworld.com
[]) [] []V[] [])
