I have the 2000 2300V and the throttle will not hold by itself when it is below 1/2 throttle, in other words, if I let go of the throttle at below half it will return to idle. How does one tighten this up so it will hold?
You might have to actually loosen it. I adjusted mine (thottle cable) last year and over tightened it and it wouldn't stay put. I let off the tension a bit and and that problem cleared it right up.
The throttle at neutral looks like this... | pushed down 90 degrees .... __ from there pushed down further to here... / is not much of a difference in RPM. Maybe that helps?
Common Sense is not so Common
