How was the maintainance on the T105's? Did you need to add water often?
Which batteries are best for audio power??
Tanner,
Interesting!I think I'm going to go and get some t-105s Have you had any problems with them during the hot OK summer? How often did you have to check them to make sure they were ok?
Let me know!
Bako Cali where I live is just as hot as OK, so if they worked last year for you, they should work here for meOriginally posted by G-MONEYIt hurts me to say it but go OU but only for this weekend!!!!
Originally posted by spharis View PostVenting isn't hard if you know the sub specs, and the frequency you want to tune to. I build all my own boxes.
yeah venting is easy, I'm also talking about making my batt. box vented.Originally posted by G-MONEYIt hurts me to say it but go OU but only for this weekend!!!!
If you want to go big.....make the trip to WA for these
http://cgi.ebay.com/ebaymotors/Heavy...ayphotohostinghttp://www.wakeboatworld.com
[]) [] []V[] [])
Originally posted by spharis View PostIf you want to go big.....make the trip to WA for these
http://cgi.ebay.com/ebaymotors/Heavy...ayphotohostingSuccess is the ability to go from one failure to another with no loss of enthusiasm.
Winston Churchill
Originally posted by Coach View PostThe 40+ is a great charging unit. As for how everything is wired I have 2 banks. The starting battery is one and the 3 batteries are another.
Originally posted by TigeDuner View PostI checked the specs on the Xantrex 40+ charger and it states that it is for 400 ah batteries and up. Would this overcharge 100 ah batteries or just charge them faster?Success is the ability to go from one failure to another with no loss of enthusiasm.
Winston Churchill
Originally posted by chpthril View PostMRMoffat1, If I were going to add an onboard charger, I would wire the chargers POS cable right to the center post (labelled "charge output from alt" in pic above) of the Isolator and attach the GRD to the engine. This would be just like the engine running.
chpthril, Checking the battery compartment today. The warning label on the battery cover states the battery needs to be disconnected prior to charging. Does the isolator mitigate this case? See picture.Attached Files
Originally posted by MRMoffat1 View Postchpthril, Checking the battery compartment today. The warning label on the battery cover states the battery needs to be disconnected prior to charging. Does the isolator mitigate this case? See picture.The fear here is from the big automotive style charger/starters that can put out 16 to 18 volts
when on hi/boost. This kind of voltage spike can fry electronics.
Any onboard multi-stage trickle charger (battery tender) probably will not exceed 14 volts which is the normal volt output level of the alternator.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by TigeDuner View PostI have found the 40 amp units cheaper than the 20 amp units. Should I just keep looking for the 20 amp?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by spharis View PostI would go with the slower charge. It will help maintain the battery life. There is a reason battery conditioners have a slower charge than a jump charger.
