I am sold on the Xantrex 20. Should be able to handle the two Costco deep cycles and my starting battery easily.
Which batteries are best for audio power??
Coach,
where can you find the t-105 for 60-80? I'm looking at getting 4 for the system i'm installing. I need to get a charger as well, so I'll look into your links you put. On the wet cells is all the maintaince you have to do is charge them at the end of the day, and then check the water levels every week or two? It's hot in Bako, so just wondering. Thanks for the info.
DomOriginally posted by G-MONEYIt hurts me to say it but go OU but only for this weekend!!!!
well that's an option for me tigeduner. The costco would for sure work. Is it really true that 2 of the 12v are going to be the same as the 4 6V? If that's the case I'll get 4 of the 12v and run them in parallel and will have plenty of juice, or maybe just get two to start off with, and if I feel I need more, then add some.
Running wire and what not is not a problem. I already have a good idea of how I'm going to do it all, so it will be really sweet when it's done. I'm going to make my own boxes for protection and stuff so I can wire them easier. Then I'll line-x it so it's waterproof!
The problem now is do i build my own box for the subs, or have someone make me a trick box. Not really sure on that one.
Wonder if anyone on here knows any sub box makers that want some side workI tend to make my own, but thought about this time having one made since It's going to be a big box (4 subs).
Originally posted by Domsz06 View Postwell that's an option for me tigeduner. The costco would for sure work. Is it really true that 2 of the 12v are going to be the same as the 4 6V? If that's the case I'll get 4 of the 12v and run them in parallel and will have plenty of juice, or maybe just get two to start off with, and if I feel I need more, then add some.
Common Sense is not so Common
Doms -
Making your own box shouldn't be that tough. I've been researching it and its pretty easy. Its just a matter of thinking it through and planning it out. If you have a Lowe's or Home Depot, just take your plans, and for a small fee they'll cut everything for you. The only difficult part would be if you are doing some venting etc. That might get a little tricky
Here are some good links (Sorry if you've already seen these):
http://www.crutchfieldadvisor.com/IS...build_box.html
http://www.diysubwoofers.org/Reality is only an illusion that occurs due to a lack of alcohol.
Originally posted by TigeDuner View PostDom, you should look into the Costco deep cycles. They are $60.00 each and are 115AH rated and are 12V. Two of these should be the same as 4 of the T105's. Costco has a great return policy too.Success is the ability to go from one failure to another with no loss of enthusiasm.
Winston Churchill
Originally posted by Coach View PostHere is the charger I have- this is what the stereo shop put in and likes on the boats they do (over 200 boats a year)
http://www.xantrex.com/web/id/69/p/1/pt/7/product.asp
You can seperate your starting batter from your stereo with an isolator or a perko switch. I use a perko switch.
Originally posted by TigeDuner View PostCoach, Does your charger just have a male plug on the end of it to be connected to an extension cord?Success is the ability to go from one failure to another with no loss of enthusiasm.
Winston Churchill
Originally posted by TigeDuner View PostSince I don't have the rear compartments like your RZ, I suppose I will make a short pigtale off the charger and mount the charger near the perko switch and batteries. Maybe on our next boat, somebody else can do the work for me-not this time.Success is the ability to go from one failure to another with no loss of enthusiasm.
Winston Churchill
I went with the Xantrex 40+ charger. Works great. I didn't do it once this summer, but if I were to drain down my 4 T105's, this charger would get me pretty close to full charge by the next day. Since there are two hook-ups I just disconnect my parallel connection between the two 12V strings and charge the two strings independantly. So in other words I have two 6 volts wired up for a 12V string on of the connections of the charger, and the same on the other.
I actually am performing a bit of a experiment this winter to see how well these T-105's hold up. I left one 12V string at about 50% and am leaving them all winter that way Although they are seperated into the independant 6V's and totally disconnected from everything. If I ruin them, I'll replace them under warranty. I know my trojan wholesale distributor here and I told him what I was doing before I did it, to test them. He said he'd take care of me. He said he's had customers do worse. He swears up and down these thing will spring back perfectly. Guess we'll see.Being a major OU fan and a staunch conservative.... I am perpetually vexed w/ the conundrum of who to hate more. Obama or the Univ. of Saxet.
