Originally posted by TigeDuner
View Post
Which batteries are best for audio power??
Winston Churchill
Originally posted by chpthril View PostA Battery Isolator is the best way to go I think. The alt will keep a charge on all your batteries while the engine is running but it keeps the deeps and starter separated
I've got the same boat - 06 22Ve. I'm looking at your setup. Right now, I have a Kicker 350.4 and a Kicker 650.4, so looks like I can stay with the Tige EIDB dual battery setup. What's the best way to add a trickle charger or other?? to charge the two batteries in the garage?
Thanks Spharis - I calculated at 2 ohms because that would draw more power than 4 ohms. So in theory, I should be < 60 amps if I'm running at 4 instead of 2.
Sounds like a battery isolator and a charger are in order. Anyone have any recommendations on chargers besides the Xantrex? I'll probably buy one, but want to see all the options.Reality is only an illusion that occurs due to a lack of alcohol.
Originally posted by Coach View PostSeperate your stereo bank and your starting battery. If you do this you will never worry about getting suck. I have been doing this for the last 5 years and have not got stuck once (knock on wood).
You can either do this physically and have the ACC bank "stand alone" (not wired to Alt or Starter) and power your stereo. This would require a recharge at the end of the day.
Or you can do this electrically with a Perko type switch or an Isolator (or both). Depending on your Sys draw, battery(s) Ah rating, Alternator output, and how long you run the battery(s) between charging, you may need to plug them up to a charger after a day on the water. The average alternator will not recharge a dead battery nearly as fast as a charger.
I've got the same boat - 06 22Ve. I'm looking at your setup. Right now, I have a Kicker 350.4 and a Kicker 650.4, so looks like I can stay with the Tige EIDB dual battery setup. What's the best way to add a trickle charger or other?? to charge the two batteries in the garage?Last edited by chpthril; 02-05-2007, 01:18 PM.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Interesting page on battery isolators.
Its written for cars, but should apply to boats as well.
http://www.bcae1.com/battiso.htmReality is only an illusion that occurs due to a lack of alcohol.
Originally posted by jleger98 View PostMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by jleger98 View PostWhats the difference between a 10 amp charger, and a 20 amp etc. In other words, am I better off with a 20 amp if all I need s a 10 amp? How can I decide?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by jleger98 View PostSo would that be max output of the audio system, or max amps of the batteries...I guess I'm still a little unclear on that.
The higher the output of the charger, the faster it wil recharge the batts.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
You want a three stage charger. Xantrex and Pro Marinar are two good on board chargers you can buy. The larger the bank of batteries the more amperage you will want. 20 will cut it for most people. I use to use a 6 amp that would take 2 days to charge my Trojan T-105's back up.Success is the ability to go from one failure to another with no loss of enthusiasm.
Winston Churchill
