Anyone have a suggestion on a ballast system for a 06' 20v?
Ballast
Originally posted by Studman View PostI currently ride with two 600 pound fat sacs one in the walkway and one one the floor of the rear sitting area. The wakes good when you throw in a couple of people but im looking for a bit more meat when its just 2 or 3 of us.The sun never sets on a badass
An integrated bow sac will not fit in the front of a 20V. Put 400# sacs in the rear lockers, a 600# sac in the walkway and then put about 200-300 pounds of lead in the front of the bow.
If you want a good wake out of the 20V you have to put a sac in the walkway, just crappy design by Tige.
Lee is right, you almost need 50/50 distribution in the 20v so it won't porpose and for taps to actually work. Otherwise you will have taps at 1 and the boat will still start to porpose every once in a while.
I guess you could put that pro x nautique sac in the bow, just sit it on top of the cushions, then you might not need the one in the walkway.
For aftermarket ballast you need to look at rival ballast systems.
Originally posted by akdoc View PostAn integrated bow sac will not fit in the front of a 20V. Put 400# sacs in the rear lockers, a 600# sac in the walkway and then put about 200-300 pounds of lead in the front of the bow.
For aftermarket ballast you need to look at rival ballast systems.The sun never sets on a badass
Originally posted by akdoc View PostYou got it!! The seats come up but there is little room. Lead bags are key!
TigeDuner is correct. Water ballast is neutrally buoyant, and lead is not. I guess it all depends on how you want the wake.
We had a switch V, we loaded up the factory ballast, put 250 lbs. more in each rear locker, added a 550 to the walkway and made people sit in the bow. If you have a decent crew make people ride in the bow if you don't want to use lead.
Originally posted by akdoc View PostTigeDuner is correct. Water ballast is neutrally buoyant, and lead is not. I guess it all depends on how you want the wake.
it could workThe sun never sets on a badass
Tigé Jedi
- Feb 2004
- 5557
- St. George, Utah
Wannabe,
I have done the rubbermaid containers before actually, and they work just fine. We even just filled them with a 5 gallon bucket (that was a workout!). You need to get some giant garbage sacks to line the container with and then once the container is full of water, seal the sack by twisting the top and then putting a twistie tie on it. If you don't, the water splashes all over and your rubbermaids will lose a lot of water.
The price could not be beat!Be excellent to one another.
