This is our second year of ownership of our 2003 21i Type R. So far we have replaced a bilge pump, starter, perfect pass servo motor, steering cables, transom carpet, battery, impeller ( no big deal ), and added an amp cooling fan. Thats about 8 things in 2 years. What have you guys replaced on your boats?
What have you replaced on your Tige'?
I replace the impellar once a year wether it needs it or not along with the fuel filter. Replaced the evil Metcraft tower. Prop. Leaky Taps ram.
Basically nothing. The boat has been bullet proof, so far as boats go that is. I've had it for 5 years now. That's a pretty badass service record. The Taps ram was the only thing that really "broke" and it was just leaking (bad O-ring). Bennett replaced it free of charge even though I was two months past warranty. Tower was an upgrade as it hadn't broken yet, although I'm sure it would have. Prop was an upgrade as well. Everything else has been regular maintenence. I've only been stranded once and that was my own fault for surfing with only a few gallons of fuel left. Basically ran it dry and sucked up some tank shmag and clogged the filter. Replaced that and was back in business.Last edited by NICKYPOO; 01-05-2007, 07:13 PM.You'll get your chance, smart guy.
Originally posted by Tequilasun View PostI replaced a speaker cover, and I need to replace my 22v sticker on the port side and Tige one on the back after a gas burping incident. I'll probably just leave them off though.Common Sense is not so Common
hmmmm lets see...
seat cushions x 6 (last-7th-needs replacement)
defective propshaft x 1
right side tower base x 1
board racks x 4 (finally got monster racks)
TAPS motor x 2
visibility light on the tower x 1 (my fault)
90-degree aluminum bracket for the engine cover latch x 1
drain tube from the glove box (my fault)
steering cable x 1
thats all I can think of right now.. except for general maintenance- impellErs, oil, and trans fluid dont count.Freude am Fahren.
5 or less for me w/ a 1 yr old boat.
accu-set - didn't work from start.
raw water pick-up leaking now
now fluid in trailer brakes
That's itMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
05 22i
several cushsions/upholstery parts
tower light
2 courtesy lights
all new cup holders
new steering cable at dealer ready for install
more upholstery
replaced the trailer lights with LED
added spare tire & mount
" " transom & bow tie downs to trailer
replacing Clarion stereo set up with Pioneer deck, JL Audio sub & amp & new cabin speakers.
FAE soon
new upholstery on an '05? can you elaborate? I thought they fixed the upholstery on the '05s and later. From what I understand, the '07s use the same material that malibu uses.
For what its worth- the new towers and interiors will probably be the deciding factor in getting a new boat this year...along with more power, better factory stereo options, and a decent internal ballast. Probably going to end up getting a 24ve or an X-star- not sure yet. I kinda like the new SAN 210 too, although its a bit small for my taste.Freude am Fahren.
I replaced the tower, speakers, impeller, fuel filter, and oil...oh and gasoline. Unbelievably, I am not using the original gasoline. But I have added and am continuing to add many more accessories:
added:
Tower Lights
New Speakers
New Stereo
Mirror Arm
wakeboard racks
going to add:
alternator
isolator
2 amplifiers
Subwoofer
ballast
rival system
I was wondering when you where going to chime in Moki, you have done a lot to your boat in the short amount of time that you have had it.
For me so far its only been one tower speaker.
I am Looking to add some Wetsounds this summer. I just need to figure out a good way of painting the speaker cans since black or white wont work on my boat.
Originally posted by Matt Garcia View PostI was wondering when you where going to chime in Moki, you have done a lot to your boat in the short amount of time that you have had it.
