Oil change , 2016 r21
    Bought this boat in December. Oil change light is already on.
    Any good videos out there to show me how? Any recommendations on oil and filter? What tools will I need?
    Saw your post. I was looking for the same answer. Specifically on the Oil type for a 2013 R20. Should be similar?
      I found this video to be very informative.
      https://m.youtube.com/watch?v=Uwk0Rc...&index=12&t=0s
      I finished the oil change on my RZX2 last week with no problems. The only thing I did differently than in the video was to extract the oil using an oil/fluid extractor rather than pulling the tube through the drain plug. I attached a 1/4-in barbed adapter to the extractor tube (as pictured below) and threaded that onto the tube from the oil pan (after removing the brass “cap” from the oil pan tube). If your engine has the same tube connected to the oil pan this makes it very easy to extract nearly every last drop.
        Completely different engines and oil requirements.
