Thank you Gumby. It’s the Limited. I will look again and closer this time for some hardware, maybe through the v drive compartment? I’ve been busy replacing my steering cable. Local shops are out till July- equals diy. After reading many posts on here I have it out and ordered (I hope) the correct replacement. I have a Monster tower seems like a good tower just probably worked loose over time.
2000 tige 21V tower
Harv32, I have a 2001 2100v limited and I replaced my tower. My seatbacks were secured with wood screws in the center seam of the upholstery. The screws are hard to find, you have to get a flashlight and feel around. Once I get them off, drilled an access hole to make it much easier to get to the tower bolts.
