Help - Factory Rear Ballast
    My right rear ballast tank on my 2008 RZ2 won’t drain. I need suggestions on how to drain. I’m assuming it’s the pump but impossible to access unless you remove the tank. Also anyone tried to remove the tank. Looks to be very difficult.
    You can always access the back of the switch and test for voltage to the drain pump when the switch is on. Short of that, you would need to get to the pump, to test there. Once there, you can remove the pump and let the tank drain to the bilge.
      Chpthril can I suck water from the hose through the ballast pump utilizing a self priming pump?
        Possibly would work.
