So after two years of slapping on a suck gate and surfing I’ve decided to try and install automated slappers or surf gates. I’ve seen multiple people do this over on wake garage and I figured I could do it for a very reasonable cost and I already love my wave with the suck gate.
I’m not using a controller as that would add quite a bit to the cost and I wanted to keep it as low as possible. Just rocker switches on the dash. I’m using a piece of black HDPE 3/4” for the gates and Lenco 102 4.25” stroke to power them.
Just started making progress and should be finished in the next few days. The one thing that’s making this project slightly difficult is the curvature of the back of the hull. It is not flat back there which makes the hinges not want to sit flat. I’m using a piece of 10mm high density EVA foam between the hinge and the hull to fill that space and create a somewhat flat surface. Here are a few pictures from the progress so far.
