Aftermarket Rudder assembly/Box for 2013 R20?
    Anyone aware of an aftermarket rudder assembly for a 2013 R20? I just got the boat and I missed that when checking it out. Apparently, the part is about $900. Frustrating!
    Lets back up here. What is wrong with the rudder that is on it now?
    Oh Yeah!
      They all are aftermarket.
        Exactly this.
        My fear is that if you have a damaged rudder, there are other damaged items such as bent strut and bent shaft.
        Oh Yeah!
          Exactly. Have to suspect collateral damage if a rudder is bent.
            All this is possible. I have someone checking things out now. The DIY portion of this project got away from me. So, right now, my shop is suggesting the rudder assembly. I was just hoping there might be a cheaper option than the $900 I'm being quoted right now. I did a google search and did not come up anything really.
              $900 parts and labor? Sounds about right. Parts only direct from a retail source would certainly be less then through the shop that has their costs involved.
                Actually, it's $900 for the part alone. There is another 4 hours labor on top of that. The shop is willing to install whatever part I can find, if I can find it cheaper.
                  replaced the rudder on the r20 years back after a defect in the casting. wasn't terribly hard of a job, had a marine mechanic friend come do it and it only took 2 hours max. Jack the back of the boat up a bit slide it off and slide the new one back in.
                    I appreciate all the words of encouragement. Regardless of which way I go with the project, I still need the part which I can't seem to find anywhere?? I can't even get a response from Tige Texas parts department.
                      I assume you mean the factory. When did you contact them?
                      Most likely its a U1065 which is a complete assembly. Would have to be ordered from a Tige dealership.
                      Oh Yeah!
                        skidim.com
                        bakesonline.com
                        greatlakesskipper.com
                        connollymarine.com
                        Those components are typically based on dimensions, rather then the boat manufacturer that used it. So you likely wont find rudder by searching "tige"
                          Quick google search with kool aids number. Might be able to find something better.
                          https://www.ebay.com/itm/Bronze-2010...-/282858387967
                            Ouch! $700 for a used one that looks worn and doesn't have a rudder port? $900 seems fair for a new one. Good find though bsreid
                            Oh Yeah!
                              Yeah not cheap but just means there might be something better available.
