I have a 2006 20V and the tach and speedometer are not working, neither one cycle when the key is turned on, the speedometer is stuck at 20, and will move slightly 3-4 mph indication change with speed, the tach is stuck at 4000 and will rise to 6000 with throttle input. any ideas suggestions wire diagrams?
2006 20V Tach and Spedo not working
That is odd. I haven't seen a commander set of gauges do that. My first guess is ground. Can you get the gauges to light up when nav/anchor switch is thrown?
Since they are both doing it and odds are against both going out at the exact same time I'm going to stick with a bad connection. Either power or ground. Those gauges jump from one to the next so it may just be a plug issue. There is a link in the download section for the commander gauges. I would suggest downloading it and checking your connections.Oh Yeah!
I had the same issue with my tach last year. My boat is an 05. The manufacture (faira beede) no longer repairs my 05 gauges so I am keeping my eyes on eBay, Craigslist, and google for a used gauge and also looking for a tach hour meter to replace it, realizing I would loose some other functions.
I’ve got an 03 22v with the same issue on my Faria speedo only…50mph strong all the time. Depth temp etc all work. I watched a video on YouTube where he physically moved the needle to loosen or “exercise” his tach. It worked after. Anyone had any luck fixing theirs? This is going to be my next try unless someone has a less invasive solution
