Its a ton of work to say the least!
2001 21V riders edition seat removal
This is what happens when you strip the material. You build new ones because the old ones fall apart.
I rebuilt my seat backs from PVC Foam. Waterproof and won't rot out again or hold water.
Food for thought.
Thanks. Went for a clean and simple look. I saw another 21V on here with Th e carbon fiber silver and white. It was my inspiration. I changed it a bit from theirs to not copy exactly. I need to clean the new vinyl and protect it. What is a god vinyl protectant/ cleaner?
Working on removing the old decals/vinyl off the sides. It sure is a PIA. I started with a heat gun and razor blade. That is for the birds. Switched to using a rubber wheel on a drill but it still leaves a residue where the old decal was previously. Hope if don’t have to end up wet sanding to get it off. Was hoping to get by with something easy.
