Originally posted by Razzman
View Post
Stereo Installed
[]) [] []V[] [])
Found one....PAC makes a kit that uses the remote, so just buy this kit.
http://www.pac-audio.com/products/pr...ine%20Products
at the bottom
SC1-W KIT
Its the remote and the SC-1....so it was either that, or a steering wheel adapter. Depends on if they wanted to use the IR signal, or hard wire to connect the remote. If the hard wire was used, then they bought the CPS remote, and a steering wheel control. I have never done one so I don't know for sure. Maybe Coach knows which PAC adapter was used for the remote, if any at all.Last edited by spharis; 12-11-2006, 04:29 PM.http://www.wakeboatworld.com
[]) [] []V[] [])
Originally posted by spharis View PostFound one....PAC makes a kit that uses the remote, so just buy this kit.
at the bottom
SC1-W KIT
Its the remote and the SC-1....so it was either that, or a steering wheel adapter. Depends on if they wanted to use the IR signal, or hard wire to connect the remote. If the hard wire was used, then they bought the CPS remote, and a steering wheel control. I have never done one so I don't know for sure. Maybe Coach knows which PAC adapter was used for the remote, if any at all.Success is the ability to go from one failure to another with no loss of enthusiasm.
Winston Churchill
Tigé Jedi
- Feb 2004
- 5557
- St. George, Utah
Where exactly are your six interior speakers?
My dealer has an RZ2 and he just had four cabin speakers (the same kind by the way, and they sounded very, very good) with just two in the rear corners and the two in the bow. Tige did not do a great job on locations for the other two main cabin speakers...where did you put them?
That L5 is gigantic!Be excellent to one another.
Originally posted by talltigeguy View PostWhere exactly are your six interior speakers?
So I have 2 in the normal spots in the cabin and one across from me under the observers seat and one right behind the drivers seat and 2 in the bow.
Here is the pic behind my seat
Winston Churchill
That L5 is gigantic!Attached FilesSuccess is the ability to go from one failure to another with no loss of enthusiasm.
Winston Churchill
Originally posted by bschmaus View PostWould the EIDB system Tige installs push the wattage necessary to maximize your system?Success is the ability to go from one failure to another with no loss of enthusiasm.
Winston Churchill
Originally posted by Coach View PostIt wouldn't even be close. The set up I have gives me 300 Amp hours with the stock starting battery back in the stock location. I will run my system about 6-8 hours a day. The alternator will help some but never get the batteries back to a charged state. The 300 Amp hours will let me go most of the weekend without having to put it on a charger. I still will end up charging it up each night to keep the batteries full and prolong the life of the batteries.
(2)ZX-850 = (2)14.6A @ 215 watts
total amp draw playing tunes avg. probably 40% of that so:
22.5 amp draw.
300 amp hours should give:
15 amps for 20 hours
37 amps for 8 hours
22.5 amps for 12 hours
A full charge after a hard day and you will be golden! You should have a 4 hour reserve assuming you value your hearing.
At max output you'll push 56A, so that would equal a little over 5 hours until you hit 10V....Last edited by spharis; 12-12-2006, 04:03 AM.http://www.wakeboatworld.com
[]) [] []V[] [])
22.5 amp draw.
37 amps for 8 hours
That is awesome. Do you have formula or calcualtor to determine the info?
I just asked the stereo guys and told them what I want to do and how I play the stereo and they told me how many 2150 to buy.Success is the ability to go from one failure to another with no loss of enthusiasm.
Winston Churchill
