It is a possibility. I had to put it in storage already, I’m going to tackle it in early spring.
Transmission removal
Originally posted by Kylemac70 View PostKonaking why are you having to replace your trans on a 4 year old boat?
So its been almost 2 months and the dealership finally called and said it was done. for the record There was many calls in between that time and warranty discussions and the dealer was busy with winterization and i didn't need the boat back in a hurry anyways.
so when the dealer called I asked about the warranty and the 1st question out of the guys mouth was " I didn't know this was a warranty job" WTF ???? I asked to talk to the service manager AKA the guy i dropped the boat off to and said it would probably be covered under warranty and was told he didn't work there anymore.
Nice bit of info to know seeings how i had just talked with him 2 weeks earlier. Hmmmmm !!!!!!
So again what about the warranty, " well are you the original owner"?
No i said, at which point I was told by the dealer they will contact Indmar and see if its a warranty item.
I then asked what they found and why it seized and got some BS answer that there was "probably" water in the transmission.
there was no water in the trans or in the V drive when i purchased the boat 8 weeks earlier and have since ran it on the lake 4 times prior to the failure.
Anyways I have still not picked up the boat because I am waiting on the Dealership (whom i have absolutely no confidence in) to contact Indmar and get a straight answer on a warranty and as to why the V drive which is coupled to the transmission failed. once again I would speculate that the oil seal failed and dumped the oil out of the V drive gear box and pretty much let the trans unscathed other than possible dampener plate damage.
as it now it was a 6k with a winterization as the temps here in Utah have gotten pretty cold.
Ill let know how it turns out.
Oh ya i still have a touch screen that needs replaced at a cost of 2k
