Ok so I’m going through these steps with a 2004 22v
So far I’ve only located 3 blue drains 2 on port side and 2 hoses that have a little thumb release hose
Now I’m reading to remove the knock sensor?
Also where do I empty out the trans cooler or vdrive water drain?
Would you run the RV safe coolant after? If so what do I need to do so
Live in Michigan and it’s getting to the 30’s quickly
