New Tige owner
    New Tige owner
    What’s up guys. Just purchased a 2000 21V riders edition. First owned Tige previously owned a Malibu skier euro. Excited to see what this boat will do. Need to replace the interior and do some maintenance but have all winter to get it done.
    Did you happen to check your prop? Sometimes you can run over something, and get debris wound around it underneath, you wouldn’t know unless you got underneath it and looked at it.
      I did check the prop. No damage.
        Hopefully a fluid change helps. Be sure the throttle/shifter linkage is allowing it to go into gear properly as well. worse comes to worse I'm sure it can be rebuilt.
        Oh Yeah!
          Check for any fluid in your bilge. They are notorious for the o-ring going bad and leaking out while under load. Keep some fluid handy and check it while warm. Top it off and make sure you have the right level in there.
            Thanks for the advice guys. Hopefully this weekend I’ll get all the fluids changed and then go back out for test run.
