I recently purchased a 99 tige 2100v with a 350 Mercruiser Bluewater Inboard in it, I am just curious what significance the "bluewater inboard" designation have? I have found conflicting info on other forums, thanks!
It looks like it has been around saltwater with that surface rust. Where are you located or where did the boat come from?
The boat was only used in freshwater, up in Orange County at Canyon Lake, where I purchased it from about 4 months ago. I use it in San Diego, I do store in near saltwater and use it in saltwater, however, most of the surface rust was present when I bought the boat.
I am just trying to figure out the engine, I am starting to think maybe the cover was swapped at one point, because the serial number comes back at a Mercruiser MPI Tourn Ski engine, and doesn't show the BWI (Bluwawter Inboard) when pulled up.
