Problem with 2005 Tige direct velvet drive...Does not engage the propeller in forward or reverse..Any ideas???
2005 Tige transmission problem
Fluid level first. Then check to make sure cable is moving the shift lever. Third, when engaged, look to see if the output flange is spinning or not.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
