A Huge thank you to Justin at tige’. Thank you for all the swag. Wife loves the shirt, (perfect Predators colors) and don’t get me started on the XL you sent me. It’s perfect and will get a lot of use next summer, especially from the folks that want a free ride at THEIR convenience. LOL. “My Boat, My Rules”
Help Needed - Old Owners Manuals = Free Tige Swag
Can anyone share with me a 2007 22ve manual? In addition to that, any chance you have information about the factory ballast system? I bought the boat used, and it runs great, but have a couple issues. Ballast won't fill, throws the breaker. Front Ballast doesn't work at all. And I have this really annoying beep sometimes which I understand may be caused by an oil pressure sensor. So looking for the manuals to start working on it. Thanks in advance.
Originally posted by Cma512 View PostCan anyone share with me a 2007 22ve manual? In addition to that, any chance you have information about the factory ballast system? I bought the boat used, and it runs great, but have a couple issues. Ballast won't fill, throws the breaker. Front Ballast doesn't work at all. And I have this really annoying beep sometimes which I understand may be caused by an oil pressure sensor. So looking for the manuals to start working on it. Thanks in advance.
Regarding ballast, you have 4 “tanks” and 8 pumps - 4 fill from near the vDrive, and 4 drain at the actual tank. If you are throwing a breaker when “filling”, you have a short to that pump. If the front ones don’t fill at all then those pumps are bad or are not getting power. You need to pull the middle floor panel up and take a multi meter to the wires and see what’s going on IMHO. Mike will know.
I’m the wrong person to ask on the oil sensor but having a dealer pull the engine codes should quickly tell you which sensor is bad. And annoying tone is a bad thing. If the oil pressure is actually low.. that’s even worse
Good luck man.
- 1 like
