I have a 2013 Z1. The throttle cable is starting to feel stiff. Has anyone pulled that cable out to lube it? Just looking for some tips before I dig into this deeper.
Your 2013 is drive by wire, so no actual throttle cable. If the throttle lever is stiff beyond the point of engaging the transmission, id say its the tension screw for the throttle/shifter is a tad tight.
