Originally posted by Bamer
View Post
Winterization question
I was able to pull the necessary plugs yesterday and drain the water from the raw water portion of the engine and the V drive. Is there a center hull drain plug somewhere on the RZX2? I thought the water in the middle of the boat near the V drove just drained to the back of the boat, but apparently not. I even trailered the boat up a steep hill yesterday to try to get the remaining water out, but was still left with a gallon or two of old stinky water. I had to suck it out with a shop vac. What am I missing here?
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Our 24Ve works the same way with respect to bilge water. No hill is steep enough to drain the Convex V hull out the back drain, and ours doesn't have center drain plug either. We use the shop vac method you described.
