Does anyone know much about Taps T3? what are the biggest differences? would you be able to get e T3 system installed on a 2019? is the only difference the actual plates and their shape or is there more mechanical differences that would make it hard to upgrade to them?
Taps T3 upgrade
GSA plates now, on the 2020 "GO" system, v's Tige's plates.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by Surf406 View PostI’ve done my last few boats with gsa and it’s well worth the change trust me I spend tons of time fine tuning and dialing stuff in.
I am thinking of doing this on my taps3 2018 R23 but have the smaller tt2 screen. I can dial in the wave fine and with big weight it's great once dialed, but because of the way ballast has to be set up now for goofy (lots more to surf side), it makes transfers not possible (dirty backside wave...).
im hoping with gsa plates i can weight the boat more evenly again to take advantage of the great surf hull and weight and full transfer capabilities. also, making wave less "sensitive" if that makes sense. would you say this plate swap to gsa-style accomplishes that?
tia
cnote
Instead of doing the fiberglass work, I built a cover plate the same shape as the actuator mount. I then sealed it and screwed it to the transom using the original screw holes. This made it possible to return to stock if I ever need to. I used polished SS, so it stands out against my black gel coat. I could have easily painted it black and no one would ever know it's there.
Originally posted by UNSTUCK View PostInstead of doing the fiberglass work, I built a cover plate the same shape as the actuator mount. I then sealed it and screwed it to the transom using the original screw holes. This made it possible to return to stock if I ever need to. I used polished SS, so it stands out against my black gel coat. I could have easily painted it black and no one would ever know it's there.
Originally posted by Sublimer23 View PostI'm happy with the wave as it is. However hauling around 600 lbs lead in the rear makes the boat tow terrible. Bouncy and tail happy. It would be nice to have the same wave and not haul around that lead.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
