Speaking of Rear View Cameras...
    Our camera basically doesn't work. I don't care, but my wife likes to use it when she pulls me out of the water, that and we have one, so it should work.
    It's like an old TV with bad antenna reception. If I could, I'd give the screen a few good whacks on the side of it and I'm sure it would work again. Sometimes I get the "snow" with the rear view just barely showing and sometimes its the lines that move down the screen. Sometimes the screen is just black.
    I have played around with the RCA connection behind the screen and am fairly confident that is not the issue. I haven't looked past that though.
    Is this a common issue? Is there a common fix for it?
    Thanks.
    Typically the failure is the female to female adapter.
    Swap that. If the issue stays, contact me and I will get you a replacement camera and cable.
    Oh Yeah!
