I've had issues for a long time with the starboard side tower speakers cutting in and out. Usually when this happens I get under the helm and twist the RCA connection coming out of the Clear screen. Last Saturday I noticed an unusually loud hiss/static coming from these speakers when I muted the music. I always have static, but it was much louder this time. I got under the helm last night to do the normal twist of the connections and retaped with electrical tape. After doing this I noticed all four tower speakers weren't working at all, but was still getting the normal hiss/static. I did not test them before adjusting the RCA connection, and I never touched the port side connection. I verified that the tower speakers were not muted. I turned the Clear off and on a couple times. I messed with the RCA's going into the amp. Even pulled them and installed them into the other amp. The speakers associated with those inputs did not work. I then removed the starboard tower RCA at the Clear and installed it in to the port aft RCA cable. I didn't get any sound out of those aft inboat speakers. That tells me the Clear is not sending the signal for the tower speakers.
Anyone ever have this issue? What was done to correct it?
Thanks.
Thanks.
