2019 R23 raptor 400 with dual battery setup. I recently noticed the ProMainer ProSport12 charger is not working. The procedure I use is when boat gets back to storage, I turn battery switch to OFF, then plug in charger to AC power. The blue AC Power LED immediately comes on, stays on solid blue and that’s it. No other LEDs come on. The last time I pulled the charger panel to verify the LEDs was very early in the season, maybe even before I had the 200amp alternator swapped out in which the alternator put out 18v on the crank battery according to touch2 screen.
Thoughts? Is the charge broke? How does the charger respond if the batteries are not connected? I didn’t see this fault behavior in the user manual.
