This probably belongs under another heading, but here goes... I've been trying to wet sand and polish the gelcoat to get rid of the ghosting from prior decals. I don't seem to be making any progress. I recently purchased the most aggressive 3M compound but even that didn't make much difference. Overall, the hull doesn't look terrible, but compared to the black underneath it looks faded. I have not yet tried any wet sanding below 1500 grit. Is that the issue? What grit should I be starting with, and what increments would you use to follow after (i.e. 800, then 1200, then 2000)?
Gel coat restoration
I have a 2003 22v that is black and I have removed all the decals and wet sanded it a few times starting with I think as far down as 400 grit and going up to 2000 then polishing with Hula boat care products. While wet sanding does do a great job of freshing up the gel coat I also could not get rid of the ghosting from the original decals. I also kind of think once they have been in the sun for too long you might not get it all the same again.
