Here's what i just found on the web;
"Spun aluminum refers to a specific type of metal fabrication and production process known as metal spinning used with the metal aluminum.
In metal spinning, the forming process is accomplished by the use of a spinning lathe. The lathe resembles a woodturning lathe but is typically of a sturdier construction.
Spun alumininum is generally harder and thinner than other aluminum fabrication methods, and typically is used for cylindrically-oriented parts, fixtures, and devices."
