Most of us have read the rule of thumb for wakeboard weighting of 60 front/40 rear. While good to have a starting point, this was presented by pros running v-drives. With the static weight being much farther forward in an inboard, do you think this distribution holds true for direct-drives? I've been putting 100% of my extra weight in the rear lockers (granted, not much - only 250lbs of free weight last season - but it does fatten up the wake). I also Force anyone over 200 lbs to sit aft of the engine.
I'm installing a bag system in the rear lockers right now and between water and free weights, will have roughly 350lbs in theach locker (and still room for some gear). I'm thinking that this will get me closer a v-drive static weight distribution (while still enjoying my SWEET 22i seating config ;-), and am not planning to plumb for a ballast bag up front (I could always shift some free weights up there if need be, but I don't think it's likely). Thoughts?
Also curious to what weight distribution other I's (and V's) are running...
Thanks in advance, T*
