Water in the hull
    Water in the hull
    It seems like i get quite a bit of water in the hull even just cruising around at low speed. What would be the reason or is this typical? FYI, no holes in the hull.
      Engine intake impeller gasket/cover, engine exhaust hose clamp, Shaft seal, ballast pump head, ballast bag, bow U bolts, hull tracking fin bolts, Thru hull fittings, hull speed/depth fitting.
      Bottom line, dry it out with a towel and trace where the water is coming in from. You have to trace it to the source.
      Nick
      Dayton, Ohio
        Was going to say the same thing. I was getting a ton out of my ballast, but that’s easy to tell. If you don’t use your ballast, and are dry after a trip out, it’s coming from that.. it could be off your motor.. prop shaft.. all kinds of stuff.. shouldn’t be too hard to find, if there’s a significant amount..
