On the above boat I’m having problems with my MAP sensor fouling.
It initially started last year at lake Powell. Did a long run 10-15 miles and then went to the marina to get ice. Was idling waiting for the ice to return and started back out of the marina when the engine died. I had a hard time getting it started again but it finally came back to life (most likely flooded). It seemed better after sitting over night.
Brought it home and investigated. Realized it had a MAP sensor that controls the air/fuel mixture. Took it out of the top of the manifold and cleaned it with MAF sensor cleaner, for lack of residual contamination. It worked fantastic after this for the rest of last year. Great, I thought, I’ve fixed that issue.
This year it began doing the same thing. I knew immediately to go straight for the map sensor and bought a new one too.
Now I can’t make it a full day with out a ‘stumbling’ issue of the motor. The new sensor acts the same as the old, in that, it works great for a bit but then fouls again.
I’m trying to see who has had similar problems and what they did to correct the sensor fouling issues.
At this point I’m going to replace the spark plugs and replace the wires too. I’m hopeful it’s not the injectors. Looking for others experiences.
Thanks in advance!
Thanks in advance!
