2019 6.2L Indmar Raptor oil filter equivalent
    Does any know the equivalent oil filter to Indmar’s part Number 501022s. It seems they have switched from the spin on filters to cartridge style since my 2016 with the same engine. I will be emailing Indmar today to ask same question just thought if someone on here had the info already would be great. Thanks
    Volvo has a cross reference number(first oil change you will find it's a Volvo filter in there with part number on it). If you have a Volvo marine dealer in your area they will have one on the shelf. Just pull the filter and bring it with you.
      I use the WIX 57186, I get it from Amazon for ~$9, they switched to the drop in cartridge for the '17s.
        i believe sierra 18-8003 is the volvo replacement so it should work also
